Problem with AMP & Header
We seem to have an issue with our headers and AMP. As you can see on these example pages on the site the header isn’t showing properly style-wise.
https://www.deeperblue.com/freediving/?amp
https://www.deeperblue.com/beginners-guide-freediving/?amp
However other pages seem to work perfectly:
https://www.deeperblue.com/about-us/?amp
The only difference from our side between the two types of pages is the top ones have the flag set in Gutenberg to use responsive page rather than mobile theme ( as per previous thread here: https://forum.tagdiv.com/topic/mobile-theme-and-pages/ ). However, these seem to break the AMP version of the page.
Any guidance?
Hi stephanwhelan, so you are using the mobile theme with amp as in our guide -> https://forum.tagdiv.com/the-mobile-theme/ -> https://forum.tagdiv.com/tagdiv-amp-plugin-tutorial/ and the mobile page is made using only mobile editor and you still have this problem. If is so, I can make two suggestions: 1. please disable and delete all tagDiv plugin and reinstall theme from > newspaper > plugins and 2. make a test only with the theme plugins.
If the problem still persist, we can take a look at this problem on email.
let me know the results!
Hi Calin – we are using the mobile theme and amp. This seems very specific to pages where we have selected in the Gutenberg editor to disable mobile theme (so it shows responsive version not mobile plugin version). Feels like this option is causing the amp plugin to render incorrectly.
Please do a test using only tagDiv plugins and AMP, clear all cache and see if the problem of header persists.
Also, if you made the test with extra plugins deactivate and the issue persists, you can contact us via email at contact@tagdiv.com and provide wp-admin and cPanel access to investigate this issue
Also, please make a full backup to all files and the database.
