problem with banner
hi.
when i insert image with link in post (from theme Ad management) it opens that banner like image. How to make so that when i click to the image it opens link that i inserted there. it only happens when i put on bottom of article (or top of article,or in between article).
this is the code of image banner
what i’m doing wrong?
here when i click it opens article. but on website it’s opening like image gallery.
Please use this guide to properly implement your ad: https://forum.tagdiv.com/using-other-ads-non-adsense-ads/
hi Bogdan
i tried but with no result
can you please tell me how to put this banner properly so it be clikable?
Try this code:
<div class="td-all-devices"><a href="add your link here" target="_blank"><img src="add your image url here"/></a></div>
worked!
thank you Bogdan!
Hello i got a problem with the TD Composer. I only got this Message:
Errors happened during tdcIframeData.init() -> bindViewsModelsWrappers()!
What can i do?
@CologneMusic
There were three possible causes identified for this issue to happen. All described in this topic
– https://forum.tagdiv.com/topic/errors-happened-during-tdciframedata-init-bindviewsmodelswrappers-14/
Let us know if there still is a problem.
