Problem with cached pages litespeed server (does not load graphics in mega menu)
Please help, I have been struggling for a long time with the problem of loading menus in the template. In the beginning everything works fine and usually the next day around 1pm it stops working attached a screenshot from the console indicating no access to files on the server, I cleaned the cache and the next day it’s always the same, I even applied another plugin to the cache but it didn’t change anything. What could it be, please help as I am helpless with this and it is affecting the performance of the sites severely. I am currently not clearing the cache to show the problem live. Please check and help urgently.
screenshot attached
Site https://kobietawielepiej.pl
Please help me with this problem!
error 403
Hello @majsterbud!
It’s possible to be from the firewall or security module which blocks the admin-ajax.php request, which usually displays a 403 or 404 error.
If you don’t use a security plugin, please ask your host about this, maybe you have a security module that blocks this.
If you use a plugin like Wordfence please set it in learning mode.
Also, if you are using Cloudflare, please make sure that is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/, you need to disable the Rocket Loader.
Examine some other potential interfering factors: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
Let me know the results!
I will check it out and get back to you with feedback.
Thank you
Thank you
I checked on my other website eross.co.uk and I turned off the cache plugin there and it worked after turning it on the next day until 1 o’clock in the afternoon it works and then no more.
I also disabled the security plugin and cleared the cache after that, but that had no effect either. Are there any sites where the newspaper with cache works properly?
eross.pl
Hello @majsterbud!
We recommend using only one cache plugin, the WP Super Cache plugin with this configuration: https://forum.tagdiv.com/cache-plugin-install-and-configure
Do not use multiple cache plugins!
