My site shows some issues. Looking at the mobile theme, it shows that it has always changed. What is the cause and what should be done about it? And when that happens, the articles also change, and why would this happen?
My site: http://www.udumuslive.com
Hello @UdumuslivE!
I can see that you use the Mobile Theme plugin, but we have 3 options of mobile versions:
1. Responsive version: A responsive version of your website is looking similar like on desktop, edit the page with TagDiv Composer, click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB ; there you can see your mobile version and you can edit the elements there.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/
3. Mobile theme plugin: The Mobile Theme is a performance optimized theme included in the Newspaper main theme and it loads only for mobile devices. It comes with its own templates/design for page, post, category, etc so your current templates from the desktop theme will get converted to the mobile theme layout. For more details, please take a look here: https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/
If you do not need Mobile Theme plugin layout, then please uninstall it from Newspaper -> Plugins. If you need mobile pages(2), then please make sure you’ve assigned the mobile page to the desktop one.
Please let me know how the mobile version is changing(how it should appear and it’s not appearing).
Why does the mobile theme change from time to time? Made this way. But there is. What does it do?
Hello @udumuslive!
This issue is from a cache problem or a plugin conflict. Please make a test, deactivate all the cache plugins, clear the cache from your browser and see the results.
We recommend using only one cache plugin, the WP Super Cache plugin with this configuration: https://forum.tagdiv.com/cache-plugin-install-and-configure
Hope that helps you!
