Problem with Home page animated text in Momentum demo
it works in while editing & on desktop but the text animation is not visible on mobile
https://we.tl/t-xDWoEOM74G
Hello @Explorion!
It is working one time: https://app.screencast.com/3jNVhhkd5DTxP. Also, you can use 1 from 3 different mobile versions: 1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page.Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use the mobile version 1 or 2, then you need to disable the Mobile Theme plugin.
Hello so I am using the Responsive version only
& you can see the attached Screenshots the animated text is working in all the screen versions of editor & also on the desktop version of live site but it is not visible on the mobile version of live site.
Please help.
Hello @explorion!
I’ve checked the demo on a phone and it seems to work well. It could be from some plugins conflict or different browsers.
Hi Explorion, Is this problem happening when you are logged in? If no, then the problem is from the cache, this is caching the js used to change the text and for image animation, what you can do is to exclude JavaScript code or the homepage from cache.
I hope this will help you!
