If you do not have the latest version of the theme, please make update to it.
Also please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
We’ll continue to investigate this problem.
Let us know how it works.
Please try to deactivate the plugins that are not tested with our theme and see if the problem is still there.
Also please give some more details about what you do, you make some change, or you edit a page, any kind details can help us.
This reply was modified 8 years by
Calin.
i still have the same problem. When i make some changes in the theme panel, then my template settings is gonna default. I put some templates from cloud library, like; 404 Template 7, Date Template 2, Search Template 5…, and after some changes template setting is gonna default. I dont have any plugins that are not tasted with Newspaper. My plugins are; Akismet Anti-Spam, Classic Editor, Contact Form 7, Jetpack by WordPress.com, Regenerate Thumbnails, tagDiv AMP, tagDiv Cloud Library, tagDiv Composer, tagDiv Newsletter, tagDiv Social Counter, tagDiv Speed Booster, TinyMCE Advanced, WP Super Cache, Yoast SEO.
My system status;
Theme config
Registration key i 6d3597c7 – **** – **** – **** – cbf8a1478a51
Theme name i Newspaper
Theme version i 9.1
Theme database version i 9.1
HTTP channel test wordpress
Installed demo i Restro – demo ID: restro | install type: no_content
Speed Booster v4.9.3 – Disabled – incompatible plugin detected: akismet/akismet.php
php.ini configuration
Server software i Apache
PHP Version i 7.1.25
post_max_size i 50M – You cannot upload images, themes and plugins that have a size bigger than this value. To see how you can change this please check our guide here.
max_execution_time 300
max_input_vars 8000
SUHOSIN installed false
PHP extensions
mbstring available
GD library available
WordPress and plugins
WP Home URL i http://umfmostar.ba
WP Site URL i http://umfmostar.ba
WP version i 5.0.2
WP multisite enabled i No
WP Language i hr
WP Memory Limit 256 MB/request
WP_DEBUG False
Caching plugin WP super cache
That was a known issue in the cloud library plugin, we investigated at the time and provided a fix for it which eventually got implemented in the them in update 9.2.
So you could either try the fix as provided in this topic, if updating is not an option for you at the moment
– https://forum.tagdiv.com/topic/templates-resetting/
Or update the theme to the latest version.
i follow your this; – https://forum.tagdiv.com/topic/templates-resetting/
and this;
Simion C. #261887
Nov 13, 2018 at 1:37 pm
Please try the following. Make a backup before attempting. Access the cloud library files in the plugins folder, replace this file with the one provided below
– https://www.screencast.com/t/Vq7763fl
– https://www.filedropper.com/jsfilesvuethemepanelmin
Then set cloud templates if needed, check if they still reset after making this modification. Please let us know the results. ————
but the second link is expired. can you send me a now one.
thx
Sure, here it is – https://www.filedropper.com/jsfilesvuethemepanelmin
You can always download the theme from themeforest and copy the file from there.
