Problem with "Post settigns" in "Theme painel"
My site is oeconomistaexplica.com
I try to remove, in “Post settigns” in “Theme painel”, the AUTHOR NAME, POST VIEWS, COMMENT COUNT and AUTHOR BOX, but there was no change.
Also, how can i edit the articles pages, to remove the RECENT COMMENTS?
It seems that you use a cloud template for your posts, so the theme panel settings are not applied there. Please access your post and press the green button edit with the TagDiv Composer, click on that elements and you’ll find some settings for that.
For more customizations, we recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Documentation here:
https://forum.tagdiv.com/cloud-library-templates/
https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
https://forum.tagdiv.com/cloud-library-category-templates/
Check also our video tutorials here: https://www.youtube.com/c/tagdivThemes/videos
