Problem with tagDiv Composer
After last update (9.5) I am not able to access tagDiv Composer (there is a blank screen in any browser). I have no interest in trying to find out where the problem is, so I would simply like to roll back to previous version. I have bought Newspaper theme through Envato and I am not able to access the older installation file. Any way to get the previous installion version? Thanks
Hola, si tengo el mismo problema con el plugin tagdivcomposer, lo instalo nuevamente y al activarlo me sale pantalla blanco. aun con la versión de instalación 9.2.
Please ensure that you have correctly updated your theme via FTP way according to our manual from here -> https://forum.tagdiv.com/install-via-ftp/ Also, update the TD Composer plugin from the plugins section from here -> https://www.screencast.com/t/fLmjK1B5SOLW after you updated your theme. If the problem persists, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can take a closer look at your setup page.
We look forward to helping you!
We have created a guide in this regard that mentions some of the most common tagdiv composer issues people face. Please read this guide:
https://forum.tagdiv.com/tagdiv-composer-not-working/
In this case, point 2 should fix the blank screen
Thank you, adding the code to htaccess file helped.
Problem solved.
