Problem with TagDiv Composer… Saving…
Good Morning,
I have a problem with the tagdiv composer. I have not been able to modify the pages for a long time, he keeps thinking when I make changes and when saving he stays ‘Saving’ infinitely … What can it be?
From what you describe, it seems that the Composer doesn’t save the changes. So, please make sure you have an admin account in WordPress with full rights. You can check our guide for any other errors in Composer here: https://forum.tagdiv.com/tagdiv-composer-not-working/
Please check if this code is missing from your htaccess file: https://www.screencast.com/t/iN0R93dD3p from our requirements, make sure you have all the requirements as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/
Also, do these steps:
1. disable TagDiv Composer
4. install TagDiv Composer
5. activate TagDiv Composer
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
