Hi team! I am facing an issue with the TD composer plugin. Activating it doesn’t allow me to use the Ninja Forms plugin. The forms I have created keep loading and never appear. Although when I disable the plugin, the forms show up perfectly. Please tell what can be the issue and how I can fix this. Thanks!
here is my site: thewrestlepost.com
Unfortunately, the Ninja Forms plugin, zooming plugins has not been tested with our theme and therefore, we cannot say for sure if it will work or not as expected with the theme, sorry! Also, we cannot provide support for untested plugins.
This is our list with tested plugins with our theme -> https://www.screencast.com/t/cmPkh9jba4sZ
Then how can I make forms on my website? WP Forms is also not working properly.
I have seen the settings are the same as they need to be.
I made some test with WPForms and for me is working normally -> https://www.screencast.com/t/ytx1T0aoC3vr please make sure that you configure the wpForms link in documentation -> https://wpforms.com/
Please make sure that you do not have a plugin conflict with untested plugins, please deactivate all non theme/tested plugins, also if you are using child theme, clear all cache and try again.
Please provide me a link were I can inspect this problem and some more details about this problem, in this way I will be able to provide you an working answer.
here is the link to my contact page.
https://www.thewrestlepost.com/contactus/
It doesn’t display the form correctly. If TD Composer plugin is turned off, then it does.
We have install demo default theme. And try to edit news page, in that page “TAG DIVcomposer” editor not working.
http://www.meetinkansas.com/wp-admin/post.php?post_id=215&td_action=tdc&tdbTemplateType=page
Admin authentication
Please check and revert back.
The contact 7 form plugin works fine. So I guess WP Forms should also work, but it doesn’t. Can you tell me what could be the possible issue and a fix?
I have sent the link. Please check and help. I need to fix this issue asap
Hi @TheWrestlePost,
You can make update to Newspaper v9.7.1 these problems was fixed.
If there are still some problems, please provide some screenshots with tagDiv Composer activate and with tagDiv Composer Deactivate.
Hi @roobanyadav,
Please check this topic -> https://forum.tagdiv.com/topic/error-at-zones-5models-0dom-the-model-does-not-match-the-content/
Hey, here are the screenshots!
With TD Composer Activate – https://imgur.com/a/pnMkHYa
With TD Composer Deactivate – https://imgur.com/a/LqInU36
Website is thewrestlepost.com and I am using WP Forms plugin in this screenshot.
Please help. I can’t find a solution and I need to fix the problem asap.
Please try this custom css
-> https://www.screencast.com/t/fVFE2aPJ4MM
div.wpforms-container .wpforms-form div.wpforms-field-container .wpforms-field input, div.wpforms-container .wpforms-form div.wpforms-field-container .wpforms-field textarea {
font-family: 'Open Sans', arial, sans-serif;
border-color: #ccc;
border-width: 1px;
border-radius: 1px;
padding-right: 6px;
padding-left: 6px;
Set the code in theme panel>Custom code>Custom css.
Hope this will help you!
Thanks. It did work. But I want the headings like Name, Email to be bolder. I tried to change the font but it did not do anything.
Well, forget about it. I was able to fix it. Thanks for the solution!
Can you also tell how I can get the custom CSS for other types of forms as well?
Please check our documentation for how to create custom code with the browser’s Inspector or the Live CSS Box -> https://tagdiv.com/how-to-create-custom-code-in-newspaper-theme/
If you need help with this, let me know, also provide a link were I can inspect these forms.
