Problem with TD Composer
Hi, I’m having a problem with TD Composer. Every I click on “Edit with TD Composer”, it appears “502 bad gateway” with “nginx” under it. What can I do to solve this problem?
First please make sure you are using the latest theme version, download and install it again or update the existing one
– https://forum.tagdiv.com/how-to-update-the-theme-2/
Deactivate the tagDiv composer and multi-purpose plugins and delete them. Then install them again from the latest theme package. Please let us know the results.
thank you for your answer. Unfortunately, it doesn’t work anyway.
We could take a look. Please send us an email at contact@tagdiv.com and provide admin login information, FTP access and cPanel if available. Maybe we can identify what exactly is causing the issue.
Before please check the theme system status parameters
Ask your hosting provider to increase them if necessary. Also test with no plugins active if possible, except theme plugins.
I tried with no plugins active, except theme plugins. Right now, it doesn’t appear the 502 bad gateway error, but there’s just a blank page when I click on “Edit on TD Composer”. Can I do more or I have to send you an email at contact@tagdiv.com?
Send us an email and we will investigate further and make tests. Please make a backup of the website before.
I’m same error. When click in edit TD Composer button is show 502 bad gateway on screen. I can’t edit the pages. 🙁
I have the same error. When clicking TD composer button, black page shows on screen. I cant edit the pages from front end
First please make sure you have the latest version of the theme (8.7.2) and theme plugins, especially the composer plugin. The tagDiv composer is now version 2.1.
In some cases the solution form this topic worked for blank pages
– https://forum.tagdiv.com/topic/gray-page-tagdiv/
You could give that a try.
If there is still a problem, send us an email at contact@tagdiv.com and provide admin login information, FTP and cPanel access. We will take a look. Make a backup of the website before.
I am getting the same error.
I have tried deleted and re-installed TagDiv Composer & Multi-purpose plugin. But it is still throwing the error –
How to resolve this error?
@skparenting Please try the solution mentioned in the topic provided above, in similar situations that solution worked. Let us know the results.
I have deleted and reinstalled the theme.
I have deleted and reinstalled tagdiv composer & multipurpose plugin.
I have tried deactivating all the plugins but in vain.
System Status Parameters are also fine.
Still I am getting the same error.
Need your urgent response.
@skparenting We could take a look, please send us an email at contact@tagdiv.com and provide admin login details as well as FTP and cPanel access if possible. Also include a link to this topic in the email.
