Problem with themes
As soon as I fix a theme, the design is completely changed for me and I’m tired of this problem. As you can see in the first picture, it is the problem and in the second picture is the design which should appear on my website.
https://prnt.sc/OrwWJ-sxkv9y
https://prnt.sc/-mt_C0ie2hth
Hello @INTERLAJMI!
This issue with the Mobile version on Desktop has been discussed already here: https://forum.tagdiv.com/topic/mobile-site-displaying-on-desktop-site/
We have 3 options for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page.Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. There, you can see your mobile version and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use the mobile version 1 or 2, then you need to disable the Mobile Theme plugin.
Maybe we don’t understand each other. This happened to me both on Desktop and Mobile and sometimes it is fixed, sometimes not. As you can see in this photo: https://ibb.co/GnDMPcv
Hello @interlajmi!
Yes, because this is a cache issue. This layout is because you have a mobile theme or AMP enabled.
Deactivate any caching tools you’re using or these two plugins.
Hi I also have the same problem, since I bought this template I’ve always had cache problems, now the problem has come back I don’t know how to solve it, this is my site: scaricalostress.it
Hello @Ugo282!
Please install the Standard Pack plugin. It is located in Newspaper -> Plugins.
Try the solution provided above.
ok, solved, thanks
This is unfortunate. I have been trying to fix it for 1 month, the problem appears again. I followed everything you told me, it is not fixed. Now the main page is fine but the posts on the page are not fine at all. If there is no solution for it, I’m sorry, I have to buy another theme. Web: http://www.interlajmi.com
Hello @interlajmi!
Did you re-enable any caching tools? Inquire with your host provider as well.
