Problem with Visual Composer
Hello
I can´t manage blocks with Visual Composer, I don´t know exactly what is the reason. When I am going to edit a page, it displays just three tabs but not the former structure´s blocks, so it´s very strange. I can´t add any block or whatever element.
Same problem,
help plz.
This issue was caused by the new version of WP. Please update your theme using this guide:
https://forum.tagdiv.com/how-to-update-the-theme-2/ and then update visual composer to the latest version using this one: https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
Problem solved updating Visual Composer as you mentioned above.
Thanks Bogdan
Solved. Tks
