Hello
I think I might be having either a caching issue or problem with the theme
Your support forums suggest to use cloudflares “Cache Everything” option. However, this is causing a problem with the date function built into your theme. It wont change and holds the same date.
How can I solve this
I have also noticed this when using ” Standard” cache also. I have to manually purge and clear browser cache all for time to update the time feature block on all my pages
http://www.techbusinessnews.com.au
This is the guide for Cloudflare -> https://forum.tagdiv.com/cloudflare-cdn/
and this is for super cache https://forum.tagdiv.com/cache-plugin-install-and-configure/
I made a test and for me, this problem related to date is not happening.
