Problem with WP Super Cache and Mobile Theme Plugin!
Hello. Who is gettng this issue from using WP Super Cache plugin with Newspaper Mobile Theme Plugin?
When i activate WP Super Cache, the cached posts are displaying the non mobile pages, instead the mobile plugin pages, why? This is a big problem due the ADS positions.
Please tell me what i am doing wrong. I already followed your install/configure documentation.
thanks
Please read this topic as this is a known issue with the plugin: https://forum.tagdiv.com/topic/mobile-theme-problems-3/
Hello Bogdan, good morning.
The solution did not work. Why? 🙁
The Newspaper Mobile Theme Plugin is not working with WP Super Cache. Anyother recommendation?
Hello
This could be a hosting issue. Please contact your host and have them disable any hosting side cache as it can cause issues with our theme.
Next, only use wp super cache with these settings: https://forum.tagdiv.com/cache-plugin-install-and-configure/
If you use a cdn server, then please disable it temporarily or use these settings: https://forum.tagdiv.com/cloudflare-cdn/
I checked up all these settings before open the topic. But anyways…
Please disable all other caching server, cdn plugin and test without any caching at all. Also disable all plugins except visual composer. Plugin conflicts can also provide such errors.
