Problems after update to 8.1,I need help
Dear
I think i need your help:
1)when i ‘Edit with TD Composer,show Erro
Edit with TD Composer erro
2)The Mobile Theme,I done like this:
https://forum.tagdiv.com/the-mobile-theme/
but,Don’t show the menu,
setp
menu no work
erro:
menu not show
thx.
Hello bokitchan,
1)Errors happened during tdcIframeData.init() -> bindViewsModelsWrappers()!
Please do not use this setting in Seo by Yoast:
https://www.screencast.com/t/n8Cc35EofLh Also, if you are using the WP Super Cache plugin, please ensure that has been right setup according to our documentation here -> https://forum.tagdiv.com/cache-plugin-install-and-configure/
2)Also, the third important rule is to do not edit a page which was created with Visual Composer with TD Composer.
Also, I have inspected your website and I saw that you are using some untested plugins which can interact with the theme core files and causes a lot of unknown issues like this.
Clear all the caches and check the results.
hi Catalin
thanks for your reply.
I do this:
1)I setup setp follow
no plugin Seo by Yoast.
2) dell plugin ‘Disable Google Fonts’ and Upload ‘Newspaper 8.1’
Clear all the caches,but erro still.
what i can do? new upload wordpress4.8.1?!
thx.
Hello bokitchan,
Try to make a new clean install from scratch via FTP way and install only the plugins that come bundled with the theme core files and check the results. Before this, try making a full backup to your database.
Think’s your reply.
I try to make a my backup clean WP4.8 and install only the tagdiv plugins. then,active ‘tagDiv Mobile Theme’ ,All work OK.
when I delete all above. and try to make a new clean install Wp4.8.1 and newspaper8.1,and active ‘tagDiv Mobile Theme’ ,the mobile menu still not work.
all above the same mysql data.
any idear try to ?!
Hello bokitchan,
There was a problem with the new update in regard to the functionality on mobile. Please download the theme package again and install it, the issue is fixed.
Or edit this file manually as shown in the screenshot, and modify it like this
– https://www.screencast.com/t/WSi6wp4k
We are very sorry for any inconvenience this might have caused for you. Please let us know if you have any further problems with the mobile theme.
I Have the same issue. I Think its because of my own mistake -_-
edit
‘/mobile/js/tagdiv_theme.js’
Into
‘/mobile/js/tagdiv_theme.min.js’
I’m Genius. hahahahaha
