problems using the romainianews theme
when i update or add content using tagdiv composer and hit the save icon only the header successfully saved slides out, the content successfully saved don’t and i have to keep starting over cause the content won’t save, this started 2 days ago. the site has been down since. it started when i switched from the igossip theme to romanianews. what’sw going on?
Please make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also please make sure that all the settings are like in our requirements, please follow the guide carefully
When tagDiv Composer is not working -> https://forum.tagdiv.com/tagdiv-composer-not-working/
Let me know the results!
i tried it the way you stated, did not work for me so i went back to the igossip theme and it’s working just fine…
I just install the Romanian News PRO demo and for me this work normal ->http://prntscr.com/pepray
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
how do you put an mp4 video in newspaper using tag div
You’ll need to upload the video in media library, after that edit the page/template with tagDiv Composer set a column text or text with title -> http://prntscr.com/pix8kj -> http://prntscr.com/pix8pb -> http://prntscr.com/pix8yq
Hope this will help!
