First be sure to check the theme requirements guide, the most common cause for theme and theme plugin problems are insufficient resources
Contact your hosting and ask them to increase the parameters mentioned in the guide, if they need to be increased.
If there is no need for modifications in that matter, in some cases the solutions from these topics worked for tagDiv composer problems, you could give them a try if possible
– https://forum.tagdiv.com/topic/gray-page-tagdiv/
– https://forum.tagdiv.com/topic/javascript-error-td-composer-wont-load/
Please let us know if there still is a problem using the composer after you try these suggestions.
