Question on Posts and editing the color scheme of Posts
I just purchased and imported the Newspaper theme into my blog. I assume most News, Reviews, Guides etc should be posts and not pages correct? I ask because I have a main issue I cant figure out:
I’m trying to figure out how to edit the color scheme of posts (header color, text color, etc). I can change the colors for pages in the theme settings but I cant find it for posts.
Other side note: for some reason bulleted lists on my pages are the same color as the background, how can I change that?
Hello @binaryassets !
We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/homepage-how-to-build-and-set-it/
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
How have you added that list? Please provide more information about your issues and your website link, so I can help you efficiently.
Thanks for the quick response! I’m trying to load some cloud templates but I dont see the same options as in the tutorials.
I have the tadDiv plugins installed:
https://ibb.co/VQYMq7X
For instance, I’m not able to load a blank template:
https://ibb.co/BfYfTC8
I think it’s because its recognizing it as a mobile page for some reason? I tried creating a brand new page but I get the same result:
https://ibb.co/ZV1zfX8
I was able to load a template on a “post” just not sure why I cant get it working on a page. I’m sure I’m doing something wrong.
From the cloud, you can get blank templates for cloud templates, templates, and sections. If you want to add a page, this can be done from the pages section -? https://i.imgur.com/ChyRWu0.png
For posts you got a single post template, now, for pages, there is no template n cloud, only pre-build pages, sections and blocks that are pre-made.
