Question Regarding Sort Order for Big Grid 8 (TechNews)
Under the TechNews theme, the first thing is the Big Grid 8. The default sort order or Big Grid 8 is “Featured.” How do I control which articles/posts will be shown under “Featured?”
That means it will display featured posts. The theme creates a Featured category by default, in which you can assign posts
https://forum.tagdiv.com/featured-posts-2/
Check the filter tab of the grid and choose the filter/sort combination you want
https://forum.tagdiv.com/block-settings-tutorial/
Thanks Simion.
