I am not using sidebar, so the post container is too wide.
Please help me to reduce the width of post container only on PC/ laptop/ tablet with no changes on mobile devices.
I tried few CSS but couldn’t help;
Please help me.
You can set the content width in the Single Post Template from tagDiv Cloud Library -> https://i.imgur.com/x5mtwXG.png
Hi, thanks for quick update.
So, Should I create Single post template first?, Actually I am using default one.
URL – https://www.placementoffer.com/
can you please guide me, how to create and apply without changing the layouts for other pages like Homepage or Menu/ categories.
You can choose a single post template and assign it like this article https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
We have cloud templates for each template (posts, categories, tags, etc) -> https://forum.tagdiv.com/how-use-tagdiv-cloud-library-templates/
I tried for that, but there are some issues like-
After reducing width of template I don’t find any option to align the template to center.
And this template doesn’t support for mobile devices, so what do I Hav to do?
And can I reduce width of current default template anyhow?
Please provide screenshots with the settings that you made on the post.
For me looks like this https://i.imgur.com/ozVnauC.png
As per your screenshot, we can only align post contents to center with reduced width.
But title, tags, next, prev post buttons are full width and left align.
Here is the screenshot;
https://drive.google.com/file/d/1CY3-o8OYZC4xv7qDiodVSzfohnULU1LP/view?usp=sharing
Hi gimmydagar,
You can change the width for entire website, for this you’ll need to adjust the rows using tagDiv Composer, for example -> https://i.imgur.com/KzuOy4B.jpg if you want to set it smaller, select the default -> https://i.imgur.com/ZYIu7BO.jpg then set in the layout tab the width that you want to use https://i.imgur.com/exraXM0.png this need to be done per each row.
I hope this will help you!
