Responsive Images for Single Post Featured Image and Single Post Content
I’m experiencing issues adjusting responsive image sizes for my posts.
For the “Single Post Featured Image” element, I set the size to 696×0 for desktop, and it loads correctly. However, I can’t define a smaller size for mobile devices, such as 300×0. The image isn’t automatically adjusting for mobile, which is negatively impacting my Core Web Vitals score.
The same issue occurs with images and galleries within the “Single Post Content” element.
All necessary image sizes are enabled on upload.
Which mobile version do you use?
We have three options available for mobile versions that you can use:
1. Responsive version: A responsive version of your website looks similar to the desktop version. TagDiv Composer is used to edit the page. Click on the mobile viewport: https://www.screencast.com/t/XDQJedlggSB. You can see your mobile version there and edit or adjust the elements to look better.
2. Mobile pages: https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages
3. Mobile theme plugin: The Mobile Theme is a performance-optimized theme included in the main Newspaper theme that only loads on mobile devices. It comes with its own templates and designs for pages, posts, categories, etc., so your current templates from the desktop theme will get converted to the mobile theme layout. Please see https://forum.tagdiv.com/the-mobile-theme/ and https://forum.tagdiv.com/mobile-theme-introduction/ for more information.
A full explanation is here: https://www.youtube.com/watch?v=SpGkOnJeNZY
If you need to use mobile version 1 or 2, then you need to uninstall the Mobile Theme plugin and AMP.
Hi Bettina.
I use the responsive version. Already tried mobile viewport, but image size cannot be changed only for mobile.
A workaround could be to use two shortcodes with different settings and hide the mobile one on desktop and tablet. Check this guide to activate the option to see the hidden elements: https://forum.tagdiv.com/tagdiv-composer-website-manager/
That’s exactly the workaround I’m using for the “Single Post Featured Image” element. However, there’s no option to select image size for “Single Post Content” element.
Any possibility to get these features for the next version? Seems something easy to implement and it’s very important for publishers.
You can resize the image when you create the post https://i.imgur.com/Fp3lyns.jpegor use custom CSS to set the image size inside the post content.
