Setting tags so articles aren't automatically added to 'most popular' section
Wondering if there’s a way to stop articles appearing in the ‘most popular’section of the Newspaper template? I love that feature that recycles stories at the top of the template . . but some articles we publish are time focused (for example a story about market performance for a particular month) so they make the site look outdated if the Market report for 2020 comes to the top of the list.
I do want to add these stories to our site, but just want them to stay in our ‘market analysis’section rather than being floated to the ‘top stories’/ most popular list.
Am guessing I could do this with tags – so can I apply a tag that will mean the article won’t be added to most popular? thx
debra
Hello Debra!
Yes, you can exclude tags from the tab Filter of the element. Example: https://prnt.sc/RJNYyGxi6sEk
Hi . .I’m still trying to figure out how to make this work for me. Can you tell me how I can navigate to the Flex Block settings . .as shown here Example: https://prnt.sc/RJNYyGxi6sEk
Hello Debra!
Use the cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
Documentation here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
Check also our video tutorials here: https://www.youtube.com/c/tagdivThemes/videos
You can import any cloud templates from any demos you like from the Cloud Templates and assign it on your website, or you can build them from scratch by importing a blank template(in order to make it editable with the Composer).
When you edit the page with the TagDiv Composer, add the element called “Flex block” and there you can see the settings from that screenshot.
