Dear, I was editing my homepage with TD Composer and it has the sidebar which I used on nearly every page. When I complete finishing editing it, then the sidebar disappears. I am sending you the screen shots.
Site is
Dear, this error is showing in the sidebar section of the page. Please check it out and help me with the solution of the problem
If you edit the page with the composer you can’t set a sidebar with those options. You have to build the sidebar in the actual page. Split the row like this for example
– https://www.screencast.com/t/k8EPstqnFWKB
The right section will be the sidebar. You can enter content in it directly, dragging elements from the left, or use a Widget sidebar element and choose from the widget sidebars you have created
– https://www.screencast.com/t/7wlvvQ7sWx
Did you select a sidebar in the widget? – https://www.screencast.com/t/xwj7KRVNMn
Does that sidebar have widgets in it ? – https://www.screencast.com/t/RuEBmC2p7AHC
@mazougagh Do you use a widget sidebar? Also, does the sidebar name maybe contain special characters in it’s name?
– https://forum.tagdiv.com/sidebars-tutorial/
That could create problems.
I would also suggest that you try without any plugins, leave only theme plugins active. Set a sidebar and check if the same happens.
Worth to review the theme requirements guide as well, see if everything is set properly
We could take a look, send us an email at contact@tagdiv.com and provide admin login. Mention what we are to do to recreate this problem in your website. Also include a link to this topic in the email.
