Site exceeds CPU load allowed by purchased hosting plan. Please try again later.
My site constantly stops working because of the resulting overload.
In the server settings : the CPU core load was 3.5%. This is enough for 92 % of hosting sites, but not for my site! I had to increase it to 7%. But that didn’t help either. However, there are no users on the site yet.
Please tell me why this is happening , what is wrong in my settings?
I think I did everything according to the instructions.
What I can suggest to do is to optimize your website, if you follow the steps which are presented in this tutorial here -> https://tagdiv.com/how-to-increase-page-loading-speed/ you’ll be able to increase the speed of your website.
Also you can check this similar topic for more solutions: -> https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
You can try the new update of the theme v10.3.1
Also if what Satwik suggest is not working, you can also try these sugestions:
https://www.ecenica.com/support/answer/fix-high-cpu-load-wordpress/
https://www.hostwinds.com/blog/wordpress/fix-high-wordpress-cpu-usage-problem/
Nothing helps. Already 5 plugins are trying to fix the situation. The site loading results are appalling. It turns out that the theme is absolutely not optimized for SEO. Lots of problems.. The page size is huge. Third-party wordpress code blocks downloads for 825sec!
Change the subject?
https://developers.google.com/speed/pagespeed/insights/?url=https%3A%2F%2Fnewspik.ru%2F&tab=mobile
Hi Aitov,
I just tested your website and for me this is loading more faster -> https://i.imgur.com/VQKwqqr.png also on page speed test -> https://i.imgur.com/sjIiE3p.png but you still need to do some optimizations.
Make sure that you checked all the steps above, also you can check this articles to -> https://beseomyfriend.com/optimizar-newspaper-pagespeed/ it is in Spanish, but you can translate the page
Hope this will help you!
