the template is very slow. Sometimes the version on the computer runs the version for mobile devices.
after many problems with the template crashing I installed a new wordpress and the new template problem still comes back. Angielski
strona działa tak wolno, że nawet po kliknęciu w arytkuł nie włącza się on.
the website works so slowly that even after clicking the article, it does not start.
This situation appear when you are using the mobile theme plugin and the cache plugin that you have does not feature options for a separate mobile theme plugin therefore do not know when to deliver the mobile version and when to deliver the desktop version.
We tested with our theme the WP Super Cache and with the settings from our guide this is working correctly: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Hope that helps you!
I removed the lite speed and made the cockpit as in your guide, and the whole site is still slow
Please make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. Please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also, take a look here: https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/#preload-newspaper-theme-fonts
If you tried all these steps and still the problem is not solved, then you can contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– cPanel url and credentials
Our team will take a look!
Keep your data there for you and you will see for yourself. I am still struggling with such a mistake Fatal error: Out of memory (allocated 35651584) (tried to allocate 40960 bytes) in /home/klient.dhosting.pl/lucjamagoch/czasostrefa.pl/public_html/wp-content/plugins/td-composer/legacy/common/wp_booster/td_util.php on line 2883
