Smart lists and Modal popup Issue
I got some 2 issue.
1. Smart lists
I tried to assign my posts to have Smart Lists but they only show on these Post templates: Defaults and Style 1 to style 12.
They do not show on “Custom” single post templates.
*It wouldn’t be an issue but i can’t edit the Defaults and Style 1 to style 12 Using the tag div composer.
2. I added a header template from cloud templates, How do i assign my menu to show up when i click/press on the
3 lines(on the top left) just like the Demo of the “Downtown Magazine pro”- menu.
*The documentaation on the modal pop-up seems to be missing from the website!!
1. Please make sure you have the Cloud Library activated and after importing a Single Post Template -> https://www.youtube.com/watch?v=I1R3j1QYod0
You need to use the smart list from tagDiv Composer, inside Single Post Content ->
https://i.imgur.com/dbipPWQ.png according to the documentation https://forum.tagdiv.com/smart-lists/
Also, you don’t need to use the classic editor, you can use the Gutenberg editor, which is the default editor for WordPress and select/add the element classic https://i.imgur.com/9sWuCtW.png to add the smart list.
Also, please make sure you have the same heading, in the post editor and in the smart list element, please check this video -> https://www.screencast.com/t/BuFFxQKgj
2. The header is a page made with tagDiv composer, and that page is set in the modal popup element -> https://forum.tagdiv.com/modal-popup/
