Some problems
Dear Sir,
Problem One, how to organised 7days old post another separate place?All post are growing so I want to separate old post to archive old news.
Problem two, how to change permalink into like this.example : https://www.mywebsite.com/wimbledon-under-fire-over-condition-of-the-courts.html
Problem three, after installing this theme site is too much slow.I installed your td speed booster but result is same.
Problem four,is mandatory install patch?what is this?
1) Our theme does not have any options to archive old posts. This is done by wordpress and plugins.
2) Permalinks are changed from WP: https://codex.wordpress.org/Using_Permalinks the theme has no control over them.
3) Please use this guide: https://forum.tagdiv.com/how-to-make-the-site-faster/ and read this topic: https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
4) The patch is not mandatory. The patch simply contains the modified files between versions. You can use it if you do not want to replace all files when updating your theme.
