Speed ​​problems newspaper topic
Hello, I would like to inform you that the newspaper theme is heavy when it comes to doing page load tests, it always recommends CSS problems, tagdiv composer and other components of the theme, I have used the new css parser and it does not make changes, in the mobile version the same or worse for example in (pagespeed insight mark 13 and desktop 58) in (gtmetrix) one (E), performance 32%, structure 92%, largest content 4.4s, total blocking 456ms and cumulative layout 0.67
how can i improve this.
Hello !
Please provide a link to your website in order to take a look.
Good morning, the link is Newscaribe.com. Two questions, 1. I have used the mobile theme option, and it only uploads registered users, as I do to upload everyone. 2. there is no option to put the most read news or box or block? 2. Photo
Hello !
As you can see here the Page speed of your website is affected by this files: https://www.screencast.com/t/t1tjzAuRR Some of theme are theme related, some are heavy fonts, some images, Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/
For the Mobile Theme I’m not sure I understand what do you mean by registered users ?
Mobile Theme plugin is non editable using tagDiv Composer. Only the options from Theme panel.
Hello, Well, as you can see, almost everything is from the newspaper theme, the sources are from the theme, I have not loaded any additional sources that do not include those of the theme.
As for the question of the mobile theme is that it only skips or activates registered users to unregistered users, the mobile theme is not activated. How can you change that and become active for everyone.
As for the question of the panel or block that shows the most read posts, I mean the topic itself or the desktop topic, there is no that option in the newspaper topic, it is an option that should come as it is a newspaper topic, not believe? Which or how is that block activated to be displayed or is it a widtges?
system status
most read block
Hello, I am attaching you a registered mobile theme and without registering the user so that all users are not activated.
Unregistered user theme.
Registered user theme.
Hello !
Everybody sees the registered version. please make sure to refresh your page when going into the mobile viewport. On mobile the page looks like this : https://www.screencast.com/t/TvBJfq7F
To increase the page speed you can check these similar topics for more solutions:
– https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
– https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
hello good, you have not answered the question of the block or widget that can be used or that brings the newspaper theme by default could you inform me or guide me how to do to put the most read
most read block
Hello !
I’m sorry but unfortunately I cannot find anywhere on your website that Medellin category page. Can you provide us a direct link to that page so we can see what can be done ?
Hello, no, that image of the block does not belong to your topic, it is from another website, the question is if the newspaper topic does not have the most widely read option, the capture is taken from el tiempo.com. to be a newspaper topic I do not understand do not have those options that are related to the topic.
Hello !
That you can add by creating your own sidebar and simply add a flex block in it as you can see in our guide here: https://www.youtube.com/watch?v=fa7GenCHcBU
This can be done using tagDiv composer. Also you can take a look at our other video guides for a better understanding on the flexibility of Newspaper Theme: https://www.youtube.com/channel/UCOT1RiNysIPCTPSnVZskwtQ
Hello. In the attached capture I show the filter options there are.
1. only gives the option from all the time.
2. Jetpack loption from what I understand do you need other plugins?
3. the last 7 days, but I don’t understand how to activate.
Those are the options that the topic has regarding the occasions to show the most visited post.
capture last popular
Hello !
Those are all the filtering options. The 2) option will require Jetpack plugin and it will pull data from it. Option 3 Shows the most popular posts from the last 7 days using the view counter which can be enabled from the theme here: https://www.screencast.com/t/qtMrjdoBPs9S
More about the sorting options can be find in here: https://forum.tagdiv.com/block-settings-guide/
I hope this was helpful !
Hello, but I already activated the 7 days and activated the theme panel and it throws the message “no post” it does not work …
Hello !
I would like to take a closer look here. Please contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
Our team will take a look !
Hello, sent mail.
let me know when finished to close access.
Viewing 16 posts - 1 through 16 (of 16 total)
