Speed Booster plugin could not be installed.
I tried uploading Speed booster plugin and I’m getting the below error-
Installing Plugin from uploaded file: td-speed-booster.zip
Unpacking the package…
Installing the plugin…
The package could not be installed. No valid plugins were found.
Plugin install failed.
Return to Plugin Installer
Somebody help me on this.
Thanks,
Thomas Androws
http://www.waftr.com
The speed booster plugin is provided in the theme package. It can be installed like a normal plugin
– https://www.screencast.com/t/Y0VwAjW8lz0S
Or you can unzip the plugin and upload it manually by FTP in the plugins folder, in your wordpress install. Then go to the plugins section and activate it.
I am having this issue trying to Install the newspaper plugin…
Plugin install failed.all the newspaper plugin
@believer
Please follow these guides to install the theme properly, depending on the install method you choose. Newspaper is a theme not a plugin, and needs to be installed accordingly
– https://forum.tagdiv.com/install-via-wordpress/
– https://forum.tagdiv.com/install-via-ftp/
