Speed is slow on Pages made by Visual Composer
Hello
We are using dedicated server with 16 gb and i7 processor and w3total cache, post pages are fast but pages made by vc are very slow which do not have cache enabled.
Expamle urls :
http://www.pagalparrot.com/ (slow no cache)
http://www.pagalparrot.com/entertainment (fast cache )
http://www.pagalparrot.com/newsline (slow no cache)
http://www.pagalparrot.com/bruna-abdullah-goes-topless-check-out-her-semi-nude-picture.html (fast cache )
Please check if vc has problem in new versions.
thanks
I have inspected your website and it seems to be very fast on all the pages you mention
– https://www.screencast.com/t/3AyDVQ4zt
– https://www.screencast.com/t/Q4U5T9QMNz
The difference between the loading speed is very small, almost non existent. You could follow this guide to further improve website loading speed – https://forum.tagdiv.com/how-to-make-the-site-faster/
Also it is recommended to use the WP Super Cache plugin along with the settings provided in this tutorial
