Speed Issue – Is the page on speed improvement updated?
I use WP Engine and Cloudflare Pro for my website: http://www.disabledveterans.org.
I keep getting warnings about the speed being an issue in Pingdom and elsewhere. Basically, as you know, the JS is blocking the CSS, supposedly. I am using the Newspaper 8 version and the Speed plugin no longer appears in the zip file. My speed is presently 3-4 seconds, and I’d like to get it back down with the resources I am paying for.
Is there an updated article on improving speed? Is there a contractor or company TagDiv recommends for work?
Hello blk709,
I have tested your website on Page Speed Insights from Google and I have noticed that you should need to work for it if you want to achieve a good page speed -> https://www.screencast.com/t/qPRSNYUp.
Please notice that the speed of your website depends on how well your site is optimized. Notice that is not a simple task and if you do not have any experience in this regard you will do not bring good results for the theme. Also, notice that we have a speed optimization tutorial but this is addressed only to advanced users. So, if you follow the steps which are presented in this tutorial here -> https://forum.tagdiv.com/how-to-make-the-site-faster/ you can increase the page speed loading and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because the speed optimization services are not covered by our support policy, as you can read here -> https://forum.tagdiv.com/support-policy-2/ Check our documentation here -> https://forum.tagdiv.com/requirements-for-newspaper/ regarding on dedicated server to fit to our requirements.
Unfortunately, our theme does not have such an option to minify the style.css file and we cannot recommend any plugins with this functionality because is not tested with our theme. For minifying this file, we are using CloudFlare for our demo and works fine. If you want to read other views from our users, please check this topic -> https://forum.tagdiv.com/topic/tip-how-to-easily-minify-your-css-without-breaking-your-site/
One of our top members here on the forum wrote his own optimization tutorial here:
https://forum.tagdiv.com/topic/tutorial-chriss-custom-optimizations-for-functions-php-etc/ and here -> https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
Basically, these are the theme requirements
Do you still use the Speed Booster plugin? I did not see it in the download for version 8.0.
Hello blk709,
Check it with more attention because this plugin should have to be there as you can see here -> https://www.screencast.com/t/Ej2WAFJz
