Starting Fresh with Pre-designed Templates
I am presently using the Newsweek Pro theme. I would like to begin from the start, where I can add Pre-designed templates to rebuild my front page. Thanks for your help!
John Malloy
https://georgianbaynews.com/
In case that you want to change the pre-design template, then you can use this guide – https://forum.tagdiv.com/installing-demos/ in case that you want only to import a new homepage, then you can do it from tagDiv Cloud Library – https://i.imgur.com/cRmOioc.png
Also, you can use tagDiv Composer to edit pages and cloud template.
Thanks so much, Calin!!!
