Strange Problem on mobile theme page speed
It happens a strange thing
I activated all solutions to improve the speed of Page Speed.
While on the desktop everything it is ok and I have a score greater than 90 (93)
the mobile score sometimes is very low (63) in particular for
This JavaScript code that blocks the view:
http://ajax.googleapis.com/…s/jquery/1.11.1/jquery.min.js?ver=1.11.1
http://www.site.com/…s/cookie-notice/js/front.js?ver=1.2.36.1
http://www.site.com/…spaper/mobile/js/tagdiv_theme.js?ver=7.4
http://www.site.com/…cludes/js/comment-reply.min.js?ver=4.6.1
http://www.site.com/…wp-includes/js/wp-embed.min.js?ver=4.6.1
I Use mobile theme with cloudflare and supercacher, speedbooster is active
I tried to delete the cache, but the problem remains, among other things,
not every time i make the test, but often …
Any advice?
  • This topic was modified 10 years by Bintmusic.
I have tested the mobile theme with the latest version of speedbooster (4.5) and it seems to work properly. Please make sure you use the latest version of speedbooster (found in the main theme package) and make sure you disable all plugins except visual composer, clear cache and reset cdn files if you use it.
For cloudflare we only recommend these settings: https://forum.tagdiv.com/cloudflare-cdn/ and these settings for supercache: https://forum.tagdiv.com/cache-plugin-install-and-configure/
I have alsop check ed your page speed on google and you seem to get a pretty good speed: http://screencast.com/t/Gwr48qvLWi
We did not see any score of 63.
The resources you mention are nowhere to be found.
As a note, the plugin works fine but there could be external interference that can make page speed slower. Page speed customization falls beyond what the theme support can offer you.
Hi Bogdan,
i forget to say that problem above is on single post…
if you try a single post, score sometimes is about 63.
for problem mentioned above
i try to cache all but problem there is still
thanks
  • This reply was modified 10 years by Bintmusic.
Please test your homepage as we only tested optimization for page speed for the homepage not on a post. You should always test the homepage as posts have a different implementation and the results can be off. We are aware posts get a lower speed but there is little to be done about it for the moment. We will look into it in future releases but for now I cannot provide any solution for post optimization.
