So you want to use the tagDiv composer or WPBakery? Both work properly with the theme. We still provide the WPBakery plugin and update it regularly.
First be sure to check the updated theme requirements guide, top to bottom
If there is no need for modifications in that matter, in some cases the solutions from these topics worked for tagDiv composer problems, you could give them a try if possible
– https://forum.tagdiv.com/topic/gray-page-tagdiv/
– https://forum.tagdiv.com/topic/javascript-error-td-composer-wont-load/
Let us know if there is still a problem.
Hello
I use tagdiv composer and the page remains gray here are the errors of the page since the source
https://www.screencast.com/t/52aOAbv6BTM
https://www.screencast.com/t/KWSynoLcP
Thanks you
If none for the solutions from above work, we could take a look. Send us an email at contact@tagdiv.com and provide admin access and also cPanel if possible.
We may need to deactivate all your other plugins for testing, or you could test it first and let us know.
Include a link to this topic in the email.
