tagdiv composer does not work
hello team,
I would like to build a page with tagdiv composer, I launch new page ==> then the button tagdiv composer, I arrive on the construction page, but the page runs endless, no button works.
It’s been days that I want to build this page, I have version 9.1 of the Newspaper theme.
Thank
find here a screenshot of the page that does not work : https://www.gabonmediatime.com/wp-content/uploads/2018/11/bug_composer.png
  • This reply was modified 8 years by valkoprod.
So the page keeps loading endlessly in the composer. There are a few suggestions you could try
– https://forum.tagdiv.com/topic/gray-page-tagdiv/
– https://forum.tagdiv.com/topic/page-error-when-edit-with-td-composer/
These solutions solved similar composer problems.
Also please check to make sure the theme system status is set according to the guide
Worth investigating plugins as well, could be a plugin conflict between the composer and one your plugins. Let us know what you find.
