Tagdiv Composer Problem. help me pls
Whenever we try to goto the tag div composer for the home page, we are getting this error-
http://www.sitename’.com didn’t send any data.
ERR_EMPTY_RESPONSE
Rest of the site and wordpress are working fine, only the tag div composer not working…
Please make sure that the theme system status is configured as mentioned in the requirements guide. Please follow the guide carefully
and please increase all requirements that are lower.
https://www.screencast.com/t/FswObjqqmr7
Also please make a test change the homepage and try to edit it, if this works, after you edit it set it back.
Panel de herşey yeşil. İyi gidiyor. Ama composer açılmıyor.
Kodu ht.access e girdim site 505 error verdi site açılmadı.
The theme and theme plugins should work properly. As described here the 505 error would be related to the server
– https://en.wikipedia.org/wiki/List_of_HTTP_status_codes
You could check similar topics in the WordPress forum if the problem is still present
– https://wordpress.org/support/topic-tag/505-error/
– https://forum.tagdiv.com/topic/wp-supercache-causes-500-internal-error-and-cannot-deactivate/
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
