New setup and everything appears to be working EXCEPT when I add any sort of a text element via the tagdiv composer. I can get the “Edit Content” button to pop up the WP Editor and can insert the content (text) that I want, but there does not appear to be a way to get it to save the content so I can never publish it.
Please make sure that all theme requirements are set as in our guide -> https://forum.tagdiv.com/requirements-for-newspaper/ in special please make sure this code is set in .htaccess => https://www.screencast.com/t/D3i2ZA7K
Also, if you use Cloudflare, please make sure that is set as in our guide https://forum.tagdiv.com/cloudflare-cdn/, you need to disable the Rocket Loader and see if the problem persists.
The element is automatically saved.
