Hello @shooper69!
We have a guide with some tips on why our Composer is not working properly; please check it here: https://forum.tagdiv.com/tagdiv-composer-not-working/.
Examine some other potential interfering factors: https://forum.tagdiv.com/general-options-may-interfere-newspaper-theme/
If that problem is still there, then please execute these steps:
1. deactivate TagDiv Composer
2. uninstall (delete) TagDiv Composer
3. clear cache (if a cache plugin is present).
4. install TagDiv Composer
5. activate TagDiv Composer
6. clear cache (if a cache plugin is present).
Sometimes, the issue can be from a plugin conflict or a cache issue. That’s why we recommend first deactivating ALL plugins except tagDiv ones; if you are using a cache plugin, deactivate it, clear all cache (also from your browser), and see the results.
Check the guide in order to find your purchase code: http://forum.tagdiv.com/how-to-find-your-envato-purchase-code/
Hi Bettina,
This link you have kindly provided only gives the purchase code at the time of purchase and pre-download.
It shows me nothing now, having had the website operational for many years
So I am still stuck and cannot get my business restarted.
Can I not get full support from someone at TheMe Forest to help me understand why their product is broken? And what to do about it?
Thanks for your help
Dear Sir,
I used this Newspaper theme on my previous website itinfoworld.org, linkworld.us and answersmode.com but now I have created my website in NodeJS so I removed Newspaper theme from all that website.
Now I want to create a blog name ebankmobile.com and knowledgeworldbd.com But My Purchase code is not working.
Here is a screen Short – https://prnt.sc/s6OAom4TWzmy
Please help me sir.
Hello guys!
@shooper69 Please contact Envato and submit your request here: https://help.market.envato.com/hc/en-us/requests/new
Mohi Uddin You can use a license key for one single product(website), but if you want to move the theme to another website or change domain/migrate, you’ll need to reset the license key from that website: https://www.screencast.com/t/Zt12bpyX and remove the theme (delete), in this way the license will be available for the new website and you can use the theme without any problems.
Is any other way to reset the key? Because I’m unable to Active theme.
Please see this screen short – https://app.screencast.com/oNvhONpWTDP5c
Thanks Bettina,
re broken TD composer I will try those …
BUT
…one can only get one’s purchase code in the manner you describe BEFORE doing the downloads. It does not work for me.
Are there no defining codes within wordpress/the theme backend itself? So that i can get access to support for this problem
Hi Mohi Uddin,
That license is not valid, maybe it is from another theme, or maybe a character is wrong. You can get the license from the themeforest account.
Hi shooper69,
The theme and code in it are the same for everyone.
If I understood correctly, the problem occurs when you use tagDiv Composer, if that’s the case and you want us to investigate the problem, please contact us by email at contact@tagdiv.com , include this topic to can identify you and provide wp-admin and cPanel access.
