Dear TagDiv Team,
I am writing to address an issue I have encountered while using your theme, particularly in the context of implementing the shop functionality. I have been using the “newspaper” theme for approximately four years for various news websites, and it has performed admirably in this domain. However, recently, when attempting to integrate an online store into our site, I have encountered significant difficulties.
Upon installing tagDiv Shop, I noticed a drastic decrease in the overall performance of the site. It becomes very slow, and at times fails to fully load certain product pages or categories. Not only does this adversely affect the user experience, but it also slows down the browsing and purchasing process, which is unacceptable for both us and our customers.
We have attempted to identify and resolve the issues independently, but so far, without success. We have ensured that we have all the necessary resources to support the performance of our site, including adequate hosting services and platform optimizations. However, the problem persists, and we believe it may be related to the integration of the tagDiv Shop theme.
We kindly request your assistance as soon as possible to address this situation. We are open to any solution or recommendation you can provide to improve the performance of our site and ensure that our online shop operates smoothly.
Thank you in advance for your prompt attention and support in this urgent matter.
Best regards,
However, page loading speed can depend on many factors, and each website is unique from this point of view.
Unfortunately, we can only help you with some advice.
Please note that page speed or optimization are not covered by the support team. https://forum.tagdiv.com/newspaper-theme-support/
Our developers are aware of this issue and try to synthesize the composer, which is big, and fix the major problems of the theme and speed.
I recommend you use fewer features on the page, so the requests will be less as well.
Improving page speed in WordPress is crucial for providing a better user experience and optimizing your website for search engine rankings. Here are some tips to help you enhance your WordPress site’s page speed:
Optimize Images: Compress images before uploading them to your WordPress site. You can use plugins like WP Smush or EWWW Image Optimizer to automatically optimize images without losing quality.
Utilize Caching: Implement caching to reduce server load and speed up page loading times. WordPress caching plugins like WP Super Cache or W3 Total Cache can generate static HTML files of your pages to serve users instead of dynamically generating them each time.
Minify CSS and JavaScript: Minify your CSS and JavaScript files to remove unnecessary characters and reduce file sizes. This can be done manually or through plugins like Autoptimize or W3 Total Cache.
Enable GZIP Compression: Enable GZIP compression on your server to reduce the size of files sent from your server to users’ browsers. Most hosting providers offer GZIP compression, but you can also enable it through plugins like WP Rocket or W3 Total Cache.
Optimize Database: Regularly clean up and optimize your WordPress database to remove unnecessary data and improve performance. You can use plugins like WP-Optimize to automate this process.
Limit External Requests: Minimize the number of external requests your website makes by reducing the use of external scripts and widgets. Each external request adds overhead to your page’s loading time.
Enable Lazy Loading: Implement lazy loading for images, videos, and iframes so that they are only loaded when they are visible on the user’s screen. This can significantly reduce initial page loading times.
Optimize Server Response Time: Choose a reliable hosting provider with fast server response times. Consider using a content delivery network (CDN) to serve your content from servers closer to your users.
Regularly Update Plugins and Themes: Keep your WordPress core, plugins, and themes updated to the latest versions to ensure compatibility with the latest performance optimizations and security patches.
Ads can significantly impact the speed of your WordPress website since they often involve loading external resources and scripts. You can try to limit the number of ads, optimize ad sizes and formats, and implement lazy loading on your ads.
By following these tips, you can significantly improve the page speed of your WordPress website, leading to better user engagement, higher search engine rankings, and overall improved performance. Please check out the tips from those platforms: GTmetrix and Google Pagespeed Insights.
We will try to improve the shop part page speed issues and the JS issues in the next updates.
It should work if you have the Woocommerce and the tagdiv shop plugins active. Documentation here: https://forum.tagdiv.com/tagdiv-shop/
Sometimes, the issue can be from a plugin conflict or a cache issue. That’s why we recommend first deactivating ALL plugins except tagDiv ones; if you are using a cache plugin, deactivate it, clear all cache (also from your browser), and see the results.
