Text flow in connection with an image and a paragraph
Can someone help me with how I can display an image with text in a paragraph so that the text below the image takes up the entire width. In the example here https://demo.tagdiv.com/newspaper_pulses_pro/jen-kendall-kicked-off-american-airlines-flight/
it is shown. Unfortunately I can’t find the option on my site. See here: https://www.klasseik-boote.de/karl-marconi/
I use the tagDiv
THX Greeting Detlev
Hello @detlev !
You can import this single template from this demo into your website by accessing the Cloud Library: https://prnt.sc/hRvFPDZUMK4K -> https://prnt.sc/MR03hEAOj9SI
We have some settings for the rows and different stretch sizes: https://www.screencast.com/t/bsbB5P97A -> https://prnt.sc/icoqdTR9_DMS
Also, you can make a row/column/element sticky.
Hello Bettina,
Thanks for your help. Unfortunately I can’t find the way to implement your tip. Apparently I’m completely overwhelmed by the many menus. In principle I would like to set up the site similar to my old site, just with the NewsPaper layout. Would that be possible? Can you help me with this?
Hello @detlev !
You can customize the website and design it as https://old.klassik-boote.de/index.php/karl-marconi.html. Some of the features won’t work with our theme. For example: https://prnt.sc/1PPtGmaiuoBW
We recommend using cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer, which contains a lot of functions and features. Please check out our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
Hello Bettina,
Do I understand correctly that I should use another template instead of the template OldFashioned. Which one could you recommend to me? What I don’t understand is that on the page (Fugmann) I was able to wrap the text around the image, but not on this page (Marconi). Can I send you an email?
THX
Hello @detlev !
I recommend using cloud templates instead of default templates. The Old Fashioned demo is using default templates.
Do you mean this image wrapped around the text? https://prnt.sc/HuoeUzm5HBq8
Then you should align the image in Gutenberg. Check this guide: https://www.askdesign.biz/blog/2021/03/wrapping-text-around-an-image-in-wordpress-gutenberg/
Hello Bettina,
Can I order online help from you? I dont get any further.
Greetings Detlev
Hello @detlev !
Contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– the license certificate and purchase code
