Text too small to read, Viewable element not set, text too close
Hi,Support Team
I am having this listed challenges in my Google search console. I have tried all means and getting not fixed. Can some help to fixed it?.
1.Error Text too small to read
2. Error Clickable elements too close together
3. Error Viewport not set
These above mentioned are my issues currently.
Or just check the link below. Thank you
Apumone.com Errors
Please try to do these steps
1. disable all tagDiv plugins
2. uninstall all tagDiv plugins
4. re-install all tagDiv plugins again from Newspaper plugins => https://www.screencast.com/t/WLy01lbc
5. activate all tagDiv plugins
Also, for the errors, you need to use a mobile theme plugin or mobile page.
You can find more information in these articles
-> mobile theme plugin => https://forum.tagdiv.com/the-mobile-theme/
-> mobile page => https://tagdiv.com/newspaper-10-3-7-update-brings-customizable-and-fast-mobile-pages/
This is a video about Responsive Newspaper Theme, AMP & Mobile Theme, Mobile Pages & Templates -> https://www.youtube.com/watch?v=SpGkOnJeNZY
Apumone.comHi, I have uninstalled the plugins and also I tried to validate in Google search console and they are processing it. But I don’t know if I should restall the plugins again or I should wait for Google to finally fix the issues?
Below are the links Google Search Console is asking me to fix? It keeps failing when I try to validate in search console.
https://www.apumone.com/wp-content/plugins/td-composer/legacy/common/wp_booster/wp-admin/content-metaboxes/
  • This reply was modified 5 years by apusika.
bI just checked your website and it looks that your images and thumbs are not optimized, for example, you can use EWWW Image Optimizer plugin, also, you can try other plugins like Autoptimize. Your website needs an optimal speed that’s why you need to make some settings also to help for the improvement.
Also, to increase the page speed you can check these similar topics for more solutions:
– https://forum.tagdiv.com/topic/optimize-script-to-improve-site-speed/
– https://www.infophilic.com/get-almost-100-pagespeed-newspaper-theme/
– https://forum.tagdiv.com/topic/a-few-tips-for-newspaper-x-speed-high-cpu-usage-issues/
– https://tagdiv.com/how-to-increase-page-loading-speed/
However, page loading speed can depend on many factors, and each website is unique from this point of view.
Let me explain some of these factors and maybe they give you some starting points for optimizing your website.
External factors: server speed, if you are using CDN or not, the external resources loaded by your website like ads, fonts, tracking scripts like Facebook Pixel, Google Analytics, Twitter analytics, Hotjar and so on.
Internal factors: the number of elements on the page, image size, image formats, if you are using mobile optimized layouts, console errors, if you are using the Standard Pack plugin on not if you are using PRO demo or a standard one.
By the way, we have such a great result with this new update and with our new tool: https://www.youtube.com/watch?v=tnkVapqhIHc
Our tool is running only on normal pages and not for posts or categories for example.
“This custom tool performs an automatic test to find missing CSS rules applied by user interaction. Moreover, you can manually interact with a chosen section/component from the page while the tool records all the involved CSS. It will generate the final CSS file for this page and also will split the rules in Critical CSS to be loaded in the website’s header.” ( https://tagdiv.com/whats-new-in-the-newspaper-theme-10-4-update/ )
Also, if the errors appear on mobile you need to use a version as I said above.
Hope this helps you!
