the theme does not activate despite the code is correct and the panel does not s
the theme does not activate despite the code is correct and the panel does not save changes!!!
This is a guide on how to activate the theme -> https://forum.tagdiv.com/newspaper-6-how-to-activate-the-theme/ , or you can activate the theme manually => https://www.screencast.com/t/GDo5doWPUM1M.
Also, please disable if you have any plugins activated before activating the theme.
Also, make sure that all the settings are like in our requirements, please follow the guide carefully
Hope this helps you!
