Hello @babu!
Here are the font settings for comments: https://prnt.sc/Mv0WLOzaygLb
You have the option to add and use custom fonts files, please check our guide: https://forum.tagdiv.com/font-customization/
Greetings!
I have not used any of the cloud templates. I thought the font setting for the comment section should be in the “Theme panel >> THEME FONTS >> Post elements” section. But I didn’t find it there, so I feel difficult to modify.
And I didn’t understand your reply guide. If you could help me more simply I would love to get teaching.
Regards!
Hello @babu!
You can find it there for the default templates: https://prnt.sc/NNZh-ASP0eNk
We recommend to use cloud/PRO templates in order to have the possibility to edit them with the TagDiv Composer which contains a lot of functions and features, please check our tutorial here: https://forum.tagdiv.com/tagdiv-composer-tutorial/
More documentation about the cloud templates is here:
– https://forum.tagdiv.com/cloud-library-templates/
– https://forum.tagdiv.com/design-post-pages-using-cloud-library-templates/
– https://forum.tagdiv.com/cloud-library-category-templates/
