Theme panel don't save + visual editor problem
Hi Support:
I have two issues
1) It seems I can not save theme panel changes (I just updated wordpress 4.5 not sure that is the problem
2) The page editor has visual editor but no editing content to edit (please see picture)visual editor issue
  • This topic was modified 10 years by juncan347.
The new version of WP caused a few issues so please update your theme to the latest version: https://forum.tagdiv.com/how-to-update-the-theme-2/ and also update you visual composer plugin: https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
As for the theme settings, make sure you have all the system status parameters increased according to this guide: https://forum.tagdiv.com/system-status-parameters-guide/
Got them, thank you, now visual editor is working
But theme panel and options still can not save,
Please help, thanks
Please try to disable all plugins except visual composer, clear cache and reset cdn files to rule out a plugin conflict. If the problem is still there please send us an email at contact@tagdiv.com and provide wp-admin so we can take a look. Also include a link to this topic.
You are right. The problem seems related with Wordfence newly upgrade.
Not sure why others seems don’t have such issue.
I found the similar problem when editing sometimes. Use a different web browser if you are using IE. Try firefox, it worked for me.
the new version of wordpress and visual composer could have compatibility issues on older IE versions. if you use IE, make sure you use at least version 10. Older versions tend to not recognize some html 5 elements.
