– The first thumbnail of my CPT is cropped and larger than the others as you can see here
=> https://confrontations.org/la-revue/ (it’s CPT la Revue 133). Do you know how to fix this ? Featured image have the same size.
– When I toogle OFF some settings (such as SHOW AUTHOR NAME) in Theme Panel < Post Settings < Post and CPT they don’t apply in my CPT :-/ I’m forced to use CSS in my child theme. Again do you know why this is happening ?
Hello @pmarxbraun!
After changing the thumbnail sizes you need to regenerate your thumbnails using a plugin. Check this guide: https://forum.tagdiv.com/using-the-theme-with-existing-content/
The settings from the theme panel should apply on standard templates. Make sure the theme panel is saving your settings. Please check this topic https://forum.tagdiv.com/topic/theme-panel-settings-are-not-saving-2/ and let me know the results.
Hello Bettina,
Did regenerate and now they’re ALL cropped…
thanks
Hello @pmarxbraun!
I’m glad that I could help you!
Let me know if you need further assistance.
Have a wonderful day!
Hello @Bettina
Well I don’t want the thumbnails to be cropped !
On this page => https://confrontations.org/la-revue/ I’d like to have little version of featured image but not cropped please
Hello @pmarxbraun!
Then please change the thumbnails sizes and regenerate again. Check these guides too: https://forum.tagdiv.com/thumbnails-fix-strange-looking-images-on-blocks/
https://forum.tagdiv.com/theme-thumbs/
Hope that helps you!
Well I don’t find the option the change the thumbnails sizes.
I’m using M1 Block. Can you tell me where to find it ?
Hello @pmarxbraun!
Sorry for my misunderstanding. A workaround there is to use a different block which has the thumbs sizes bigger than module 1.
Bettina
No one fits, they’re all cropped because modules display images un landscape mode.
I’m using M 19 here
Cropped again
Hello @pmarxbraun!
I see that your images are so tall, unfortunately, there are no blocks sizes to fit your images. To build a new block with the sizes you need, this will require custom work which is not covered by the support team, sorry.
Thank you for understanding!
