Hello, we had an issue with our Newspaper theme. In the panel we had enabled almost all thumbs in block settings so for every image we had several copies and in one month we hit our inodes limit.
I disabled all thumbs and regenerated thumbs with a plugin mentioned here. But the problem exists, check https://trikalatroll.gr/ we are asked to enable thumbs again.
We dont want this, is it possible to use the original image in all blocks?
Giorgos
Hello Giorgos,
There is a list https://forum.tagdiv.com/theme-thumbs/ with thumbs and blocks, so please check what blocks you use, and then you can disable the thumbs that are not used. You can use the full size, but then you need to optimize the images.
Hello again, I found the right dimensions for every block except one. check our main menu at https://trikalatroll.gr/
In the other blocks the default image showed the dimensions but there we have no image at all, not even the default. Can I ask what dimension to enable so we can see the images there too?
Giorgos
This reply was modified 4 years by
giorgoskey.
For mega menu is used 218×150. Also, please let me know if you regenerated the thumbs after you select only the thumbs that you need https://forum.tagdiv.com/retina-images/
Hello Anamaria, I have regenerated the other thumbs but now I have another issue.
I updated to Version: 12.1.1 and I cant see my theme panel!!! The Newspaper menu now only has 3 options – welcome,plugins,support!!
Hello again, I had to restore my site from the JetBackup to the old version. Guess the new has some issues?
Anyway, the 218×150 thumb is enabled but still the mega menu at our site https://trikalatroll.gr/ is not working.
Another issue we got is that we publish to our FB page https://www.facebook.com/TrikalaTroll the article image are not shown! I use Rank Math SEO and even when I change the image for social posting it is not shown. Dimensions are high as FB wants.
Hello @giorgoskey!
After every modification of the images sizes, you need to regenerate them.
We recommend Yoast Seo plugin: https://forum.tagdiv.com/facebook-share/
Hello Bettina,
I regenerated them but I still got this issue at my mega menu.
Hello @giorgoskey!
Contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
We will help you as soon as possible!
