Hello
Too slow problem >
https://developers.google.com/speed/pagespeed/insights/?url=http%3A%2F%2Fwww.sourds.net%2F
Comment speed ???
Please answer
THANK YOU
I can see you are using WP Rocket but you may have the wrong settings.
I use this plugin also and have a good pagespeed score with it.
Try the settings that I use and see if there is a noticeable difference in page speed.
The only option you should ignore is the SSL option for your site.
Hope this helps
Kevin
Please use our official page speed guide: https://forum.tagdiv.com/how-to-make-the-site-faster/
And follow this topic for an info on the speedbooster plugin: https://forum.tagdiv.com/topic/tinymce-advanced-and-other-various-disabling-speed-boster/
Please also try to only use the tested and recommended plugins as in most cases plugins tend to slow down a site.
