Top colored menu with logo (header 12) – Color change problem
I used the Top colored menu with logo (header 12) and changed the color of the menu. The problem is that at the time of loading the page displays for a moment the default color and only then the color changed. See: http://poliarquia.com.br/ enter and use F5 to see the reported problem (note that for a moment the blue menu appears and only then the raised color – brown).
I already disabled cache plugin (wp super cache) but it did not work.
How to solve?
Please note this delay that you are observing depends mostly on how well the website is optimized and there are many factors could have a negative impact on page speed. You can improve your website loading speed using this guide
It is also recommended to use this recommended cache for best results with the settings specified here
Another way would be to make changes directly in the theme’s files, then these will be loaded instantly with the rest of the stylesheet.
