Using cloudflare with mobile theme
I am trying to speed up the delivery of my website. I have super cache installed and have applied the custom code to make it work with the mobile version of the theme. However when I enable cloud flare it starts sending cache’d mobile versions of the website to the desktop and vice-versa.
Can you please advise the configuration to get cloudflare working with the mobile version.
Many thanks,
Please check and see if the caching plugin and CDN are configured as mentioned in these guides
Then test again, and check if everything works properly.
